I am having a difficult time attaching this fixture to the manifold and carburetor. It has been damaged and will not align without stressing the fixture and potentially damaging the carburetor. My question is: can I cut this tube, join it with a rubber hose and clamps and expect it to function properly?
Dave Hinz
Submitted by dhinz1@gmail.com on Fri, 02/08/2013 - 13:31
Submitted by SW03-09811 on Wed, 02/06/2013 - 00:50
Carburetor question - xk 140
Dave,
The short answer is yes, as long as you use some fuel resistant hose. Have you loosened-up the starting carb support bracket and its other fuel fitting to try for some alignment?
It would probably be worth your time to try and find a used, undamaged fitting rather than to jury-rig what you have.
Good luck,
Dick
Thanks Dick,
After a lot of adjusting I was able to get the pipe connected. I appreciate your help..
Dave
